跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
What parts should I fix?
Found an old friends laptop that was water damaged a while ago. It turns on when connected to power although the screen doesn’t light up. When connected to another monitor- the screen works. Would replacing the logic board (and battery) be enough to fix the laptop?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@imacow. It is most likely that you do have a logic board issue. Since this is a water damaged MBA you will have residue etc. on the board and most likely shorted out either the display connector or the video circuitry. This would all be fixed by replacing the board. Isolated LCD damage with a fully functioning logicboard would be extremely rare for a water damaged device. Use these guides MacBook Air 13" Mid 2013 to work on your MBA. Remove the logic board and clean everything with 90%+ isopropyl alcohol. Check for damaged components. Post some images of your board with your question so that we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
这个答案有帮助吗?
得分 2
添加一条评论
If it turns on and works when connected running it through a second monitor, it sounds like the logic board isn’t the part that’s damaged. When you shine a light at the internal display, do you see anything being displayed, or is it completely black? It sounds like just the display is dead, which isn’t as bad as the logic board. It might be a good idea anyway to remove the logic board and look over it to make sure there isn’t any corrosion or other liquid damage on it before you use the computer more. Do you know how bad the liquid damage originally was or what happened to it?
这个答案有帮助吗?
得分 1
4条评论:
Thanks for the reply. Apartment flooded and the laptop was a victim. How would the display be fixed?
完成的
Ah, that's pretty scary. I'd definitely recommend completely disassembling the computer and checking over all the parts, if it was fully submerged. It's a good idea to replace the battery, because water can make batteries dangerous. Here's the guide to replace the entire display assembly: MacBook Air 13" Mid 2013 Display Assembly Replacement
That part looks pretty expensive though. The LCD might be all that's broken, so if you can find one, and a guide to replace just that, you might be able to save some money, but the repair is going to be a lot harder than just replacing the entire display assembly. It would probably be a good idea to wipe down the logic board (you probably don't need to remove the heat sink, and I'd recommend that you don't, unless you want to deal with replacing the thermal paste) and any other boards with some isopropyl alcohol (preferably 90%+) with a lint free/microfiber cloth, to remove any corrosion or other damage.
完成的
Also, have you tested everything else on the computer, and it all works fine? The trackpad, every key on the keyboard, all the ports, etc?
The battery looks pretty easy to replace, here's the guide for that: 2013中期 MacBook Air 13" 电池更换
You can get a more trustworthy and reliable battery from iFixit, and I also found a probably fine battery for super cheap on PowerBook Medic (the "Used" (not grade B) one):
http://www.powerbookmedic.com/Apple-MacB...
完成的
Actually, I’m wrong. You should remove the heat sink and check and clean under that too (just make sure to reapply the thermal paste).
如何涂散热膏
完成的
添加一条评论
添加你的答案
Jessie Mo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 125
