跳转到主内容
加入维修社区 - 创建账户
The Asus Q501LA features an Intel Core i5 4200U (1.60GHz) processor.
How to replace the RJ45 connector?
One of the 8 metal pins from the rj45 connector is missing. I wander if I could replace it by any other rj45 connector. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
paulosantos.phs  I assume you are talking about your LAN port. It may be possible. Take it apart using something like this video and see how it is connected. Your port should be soldered to the motherboard, so you will have to desolder it. Hardest part will be to find a replacement. Get a pair of calipers and measure the actual port. Then go to mouser.com or digikey.com (aliexpress.com may be another option)or similar sites and see if you find a matching port.
If you absolutely can’t find a repalcment. you could always solder a LAN port pigtail directly to the board.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
paulosantos.phs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 382
