跳转到主内容
加入维修社区 - 创建账户
Dodge Dakota 是克莱斯勒开发的一款中型皮卡。为了降低投资成本,该车不仅与克莱斯勒旗下的其他产品共享了许多零部件,其制造工厂也与全尺寸的 Dodge D-Model 共享。
How to replace the ac compressor
how do I replace ac compressor
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
alfrejdr  per repair manual
COMPRESSOR
The compressor may be removed and repositioned without disconnecting the refrigerant lines or discharging the refrigerant system. Discharging is not necessary if servicing the compressor clutch or clutch coil, the engine, the cylinder head, or the generator.
WARNING: REVIEW THE WARNINGS AND CAUTIONS IN THE FRONT OF THIS GROUP BEFORE PERFORMING THE FOLLOWING OPERATION.
REMOVAL
(1) Disconnect and isolate the battery negative cable.
(2) Loosen and remove the serpentine drive belt.
Refer to Group 7 - Cooling System for the procedures.
(3) Disconnect the compressor clutch coil wiring.
(4) Recover the refrigerant from the refrigerant system as described in this group.
(5) Remove the refrigerant lines from the compressor. Install plugs in, or tape over, all of the open refrigerant fittings.
(6) Remove the compressor mounting bolts, and lift the compressor from the mounting bracket.
For more information use this /usr/graphics/chrysler/image/cdsm-sm/lbp-cx/800c0d58
这个答案有帮助吗?
得分 2
1条评论:
Thank You! This exactly what I needed. I am replacing O-rings and accumulator also.
由完成的 分享
添加一条评论
添加你的答案
alfrejdr 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 1,529
