跳转到主内容
加入维修社区 - 创建账户
衣物干衣机维修和支持指南。
LOC Code on my dryer
I have a Affinity Frigidaire front load dryer. LOC is preventing it from running. Any solutions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
thank you so much. The clothes were piling up.
完成的
添加一条评论
4个答案
已选择的解决方案
juliet.crawford760  start of with this information
“Dryer Features
Control Lock
To avoid having someone accidentally start or stop the dryer, press Options and Select at the same time and hold for 10 seconds. “LOC” will be displayed. To remove the control lock, press Options and Select again.
这个答案有帮助吗?
得分 6
1条评论:
This worked!!!!!! Frigidaire affinity dryer and this worked! Thank you
完成的
添加一条评论
opened the door while dryer was still going and got the LOC displayed - to clear it held the options and select at same time until it beeped - hope this helps someone
这个答案有帮助吗?
得分 1
1条评论:
My dryer is an older dryer be but it still worked! Thanks!
完成的
添加一条评论
Westinghouse easycare 500 washing machine has LOC display
I have tried holding in loc button and start for 10 second s and also turning the machine off at the power source with no response
What else can I do
Please!
这个答案有帮助吗?
得分 0
2条评论:
Not this model, but same problem.
完成的
@suelong92375
What is the make and model number of your washing machine or dryer?
完成的
添加一条评论
Hi @janellemorris
Bit late but for anyone else having the same problem to activate/deactivate the child lock function, press and hold the “Prewash” touchpad for about 2 seconds until the display shows either L OC or u nL
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
juliet.crawford760 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 63
总计 7,397
