跳转到主内容
加入维修社区 - 创建账户
Motorola Moto E4 Plus(也称为 XT1774、XT1775、XT1776 或第四代 Moto E Plus)配备了 5.5 英寸大尺寸高清显示屏和顺滑的金属机身。该机搭载 5000 mAh 电池,具有防水涂层和指纹识别器。
cell got wet screen dead
Motorola e4 plus got wet, I was using for around an hour with not problem at all, now screen is dead still ringing but I cant see anything on the screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
marquez3655  just like any other device that does not get cleaned properly. It will fail and shortcicuit. In your case you want to go ahead and disassemble it. Should be pretty much the same way as on here Once disassemble you need to clean it. Use this guide 修复iPhone 的进水故障 to clean it. It was written for an iPhone but the steps are identical for cleaning every device. Once properly cleaned you want to reassemble your phone and change the battery. Always use a new battery with water damaged devices. Then re-evalauate. It is possible that you have an LCD shortcircuit and repalcing that may get your phone back to working condition. Water damage is the hardest to repair since virtually any part may have failed.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
marquez3655 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 6
总计 412
