跳转到主内容
Haswell business laptop introduced by Dell in 2013. This system is notable for being the first Haswell business laptop released, but has multiple known problems - including AMD GPU failure. A new battery will operate the laptop for ~4-7 hours, depending which one is installed.
replacement keyboard not working
Hi there,
I have recently replaced my keyboard with a non-original keyboard and it works only a few minutes and stops. After every BIOS update it works again and stops after a few minutes.
Any idea how i can get this non-original keyboard to work?
Regards,
Siviwe
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You tried to use your keyboard in safe mode if it is working then there must be an app causing error
完成的
添加一条评论
1个答案
已选择的解决方案
Need to try a DriverPack Solution Software and update the keyboard driver. If the problem persist your new keyboard might have a defect.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Siviwe Xegwana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 246
