跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone warm using facebook?
Good morning,
I was using facebook today and noticed my phone started to feel warm after about 20 minutes of use. Battery also dropped a few percent. Is this normal does this also happen to you??
iPhone X.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes this is normal. For any modern smart phone, the longer the screen is on and the more the 4G or WiFi is being used, the phone will get a bit warm and also, the longer a phone is in active use, the battery will drop accordingly.
The older the phone gets the quicker the battery will drop. You can reduce this by lowering the screen brightness causing your phone not to work as hard or use as much energy.
这个答案有帮助吗?
得分 0
1条评论:
I had the brightness turned down a decent amount already I was just wondering if its normal to be warm the quick...
完成的
添加一条评论
添加你的答案
xRock94 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 291
