跳转到主内容
The Dell Inspiron 15R 5520 laptop features a 14.88" screen, brushed aluminum finish and features a i5 core processor .
12 个问题 查看全部
Screen Glitches sometimes when I move my mouse
I recently purchased a Dell 15R 5520 laptop and I found that occasionally, I move my mouse and the display has a bunch of artifacts.
Is this a graphics issue? if so how can I fix it?
thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @dootdoot
Connect an external monitor and check if its' display is also affected.
If so (and if it happens often enough) try starting the laptop in safe mode and check if it still happens.
What OS is installed?
Dell didn't supply drivers for this model past Win 8 64-bit so perhaps it could be a driver issue if you're using Win 10. You could try installing the Intel HD Graphics 4000 Win 10 drivers and see if that resolves the problem
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Daemeon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 168
