跳转到主内容
加入维修社区 - 创建账户
LG G Pad 7.0 平板电脑于 2014 年发布,是一款由 LG 生产的安卓平板。该设备是首款配备 7 英寸屏幕和 1.2 GHz 四核处理器的平板电脑。型号为 LG-V400。
My Tablet Won't Charge!
I have tried over 8 charging cords and it won't charge, If this helps, all of the cords feel very loose when plugged into my tablet and they pull out easily. Also If it does tell me it is charging, a couple minutes later it tells me it has stopped charging because it doesn't recognise the cord. They are all the right cords because they fit the port on it. Any answers are much appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@bunnybunny
“cords feel very loose when plugged in “ pretty good indication that your port is the actual issue. Take a look at this guide LG G Pad 7.0 主板更换 The charging port is mounted on it’s own flex cable. Replacing that with something like this should fix that.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 475
