跳转到主内容
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
20 个问题 查看全部
Tears got in her phone
So my girlfriend was crying on the phone and it shut off. The morning she tried turning it on and the screen is fried (like an old television screen) and sometimes one side comes up and the other is fried. Still doesnt touch thought. What should i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @gaviii
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone’s operating design and could damage the components.
First do not turn on your phone and then you need to, with the phone turned off, remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit LG G5 guides, which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 1
3条评论:
Ok, thank you. I'm going buy the alcohol now and try it. If this doesnt work all i need it to buy another motherboard right?
I hope this didnt affect the digitizer.
完成的
Hi @gaviii ,
The screen/digitizer may have been affected as well. Disconnect the flex cables and clean the connectors and cable ends as well when you clean the boards etc.
You can only see what happens after it has been cleaned (and dried) properly.
Good luck with the repair
完成的
Ok, thank you very much.
完成的
添加一条评论
添加你的答案
Gavin Doyle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 172
