跳转到主内容
加入维修社区 - 创建账户
Sony MDR-X05 耳机于 2013 年 2 月发布,配备 40 mm 驱动单元,采用先进的直接振动结构 (Advanced Direct Vibe Structure),可重现强劲的低音,并提供良好的声学密封性和出色的隔音效果。
Right side speaker not working
Sony MDR-XB920 headphones. Right side speaker stopped working for no obvious reason. (ie: no wires were pulled, it wasn't dropped or anything of that nature). Took it apart, no loose connections. I'm at a lose at this point what to check next. Further troubleshooting ideas would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Thank you so much for this! Step 3 there was sound. Step 4 there was no sound.
It occurred to me to check the continuity of the left speaker (the one that works when I I have my headphones plugged into the jack) and that one did not work. Rechecked to make sure I didn't pull anything by plugging the jack back in, same thing: left side working, right not working.
Also, checked from the connection point from the left driver that lead to the right, no sound on the right speaker. Tested from the board itself, no sound at all from either speaker. Again, if I use the jack (double checked again just in case), I do get sound out of the left only.
由完成的 分享
Set your multimeter to the ohm scale. One probe on the tip on the jack and the other probe to the driver(you’ll have to check both to see which one is ground and which one comes from the jack. Then one probe to the ring of the jack and the other to the right speaker. That will show if you have continuity
由完成的 分享
Pretty sure I'm doing this right, and I'm getting no reading at all.
由完成的 分享
mine have just developed this problem. The pathetically small wire for the right driver between the left driver jack and and right driver has broken over time - ground still intact - i guess there are lots of bend points in the headband and its wear and tear. now the fun task of dismantling and feeding through a new stupidly thin wire
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
@katrah
check continuity from your connector to the right speaker (driver). Use this guide to see how to check it. Let us know what you find or if you have any trouble with it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Heather 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 37
总计 810
