跳转到主内容
加入维修社区 - 创建账户
Sony Xperia X 智能手机维修信息,该手机于 2016 年 2 月发布,同年 5 月上市。它是 Sony Xperia X 系列手机的一部分。
Phone Screen not working (no touch)
Hello!
A while back, I dropped my phone in water and immediately disassembled it to dry it off. The symptoms were a screen that either worked perfectly after reboot and then turned black every time the screen was turned on, or a perfectly functional device except that the digitizer did not work. So, after reading some "advice", I soaked my screen in 91% alcohol, leaving permanent marks. Then, I soaked the logic board in alcohol with a vibration assist from a washing machine. The logic board seemed to be fixed, and being a perfectionist, I tried to go a step further by using a food dehydrator to dry the alcohol marks out of the screen. However, after a while of drying (of screen only, vacuum sealed into a container with silica gel and dessicants), the screen digitizer does not work anymore.
My question is this: is the problem with the screen or the logic board? I noticed that some antenna contacts were slightly bent out of shape, but I am not sure what happened to the rest of the board. There doesn't seem to be corrosion. Keep in mind that after the laundry machine vibration, I took the board out of alcohol, but after I discovered the screen issues, I put it in for around 24 hours.
If needed, I can send photos.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
OK, I am actually out of state right now, I will post once I get back. Yes, I will order the replacement screen later.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
@froggr123 just add your pictures to the question. Use this guide 在已经存在的问题里加入图片 for that. Going by your description alone it sounds like the issue is with your display assembly. I would go ahead and replace that. If the error is on the motherboard, then there is only a slim chance of repair. You would need a schematic which is not available. Sony simply does not have those anymore. Replace the screen and re-evaluate Sony Xperia X 液晶显示屏更换
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Sony Xperia X 液晶显示屏图片
指南
难度:
中等
这个答案有帮助吗?
得分 2
2条评论:
@oldturkey03 I will upload images tomorrow (just got back from out of country). Will order screen later from Amazon. The WitRigs screen does not have a frame, and I don't want to detach the frame for safety reasons. Hopefully the screen is legit. Thanks!
由完成的 分享
由完成的 分享
添加一条评论
添加你的答案
froggr123 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 525
