跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
Disabled iPod is not recognized by my computer or iTunes
My iPod is not functioning and I have put the iPod in recovery mode in hopes to restore the device through iTunes. However, neither my computer, nor iTunes, will recognized it. I bought it from Ebay and since I have tech experience I am hoping to fix it myself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 179
29条评论
michelle, what does the iPod do at this time? Does it turn on? Does it display anything on the screen?
完成的
+ for the in depth responses.. stick with it, oldturkey has lots of experience and tristan has been very helpful too. hope all goes well and welcome to ifixit! it's nice to see another lady doing the repairs! jen
完成的
mine dose the samething it will charge but my computer or itunes wont connect to itunes it need connect to itunes
完成的
thats wat mine does
完成的
Please help me with my iPod it says connect to iTunes but I only 10 and I really don't know what that means can you please help
完成的
显示更多的24条评论
添加一条评论
4个答案
已选择的解决方案
you will have to put your iPod into DFU Mode and Restore:
  1. Connect your iPod to your computer
  2. Turn your iPod off
  3. For 10 seconds, hold both the Home and Power buttons
  4. While still holding the home button down, release the power button only! Continue to hold the home button down for an additional 10 seconds.
  5. After the dialog box explaining that the iPod was found in recovery mode has been closed, restore your iPod
If iTunes does not recognize the iPod, then you should reinstall iTunes
This video should help you get into DFU Mode
http://www.youtube.com/watch?v=bITIiGswj...
这个答案有帮助吗?
得分 115
21条评论:
I tried the above and it still didn't work. neither the computer or itunes is recognizing the ipod. this is a used ipod that i bought off ebay as is. i'm still at a loss. any additional thoughts
完成的
It sounds like your iTunes drivers are not working correctly, to fix this reinstall iTunes, and if it still does not work try it on a different computer.
完成的
also, after you reinstall, you can watch this video for additional help:
http://www.youtube.com/watch?v=5uT8Utk5T...
完成的
unfortunately i have tried everything above and nothing is working. i found tys video as well. i am wondering if something is wrong with the usb port on the ipod. could that be possible? the ipod seems to be charging very slowly as well. i'm hoping this is something i can fix or i'm out the money i spent on ebay......grrrrrrr lol
完成的
i cant thank you enough, you have been a big help. don't worry i will never hesitate to ask - that is the best way i learn. i'm pretty tech savy when i set my mind to it and the best way i learn is hands on. again, ty so much for your help
完成的
显示更多的16条评论
添加一条评论
michelle, you did not tell us what the iPod does. It all shows up on the LCD etc. Starts up okay? Does not charge and is not recognized could originate from your dock connector. First make sure that you have a good USB cable. Then make sure that you plug your ipod into a USB port that comes directly of the motherboard. no Hub or anything. Also try to charge your ipod on a wall charger. Sometimes when the battery is to depleted it will not accept a charge and will not be recognized by your computer. So that would be a good thing to replace. This way you would at least have a good starting point. If this did not resolve the issue, check your dock connector. Make sure that you clean it well and check for corrosion, debris and bents contacts. If so, it can be replaced. PITA and needs soldering. When you have it apart look the logic board over for any corrosion, broken contacts, bad cable connections, bad connectors. I prefer to use a magnifying light for that. After that you can clean the board with isopropyl alcohol (use the 90+% talk to your local pharmacist about it) and a toothbrush and clean the logic board thoroughly. I might have forgotten a step or twp but at least this will give you a start. Good Luck and let us know how it is going and if you need further help.
这个答案有帮助吗?
得分 15
4条评论:
thank you very much that was kind of what i was thinking i need to do. i know the cable is good as it is from my other working ipod, so i agree i think it may be the dock connector. i have tried charging it thru the computer usb and just a regular charger as well and its charging but its not really showing the icon that says its charging. sorry if i wasnt more in depth. i was just kind of going off what i know so far. i am trying to get into repairing ipods on a regular basis and figured i would start with what i thought was an easy one. the person who sold it just said it was disabled and when i found tys video i'm like, wow this is an easy fix.....joke's on me so far it's not...lol can you tell me will it be difficult for someone at my level of just starting out to change out the dock connector? i really appreciate everyone's input and i have this site book marked now mainly bc everyone is so nice and helpful and that really means alot to me, so thank you once again and i will keep everyone updated.
完成的
michelle, its not very difficult but you will have to learn how to solder and the dock connector is a tricky one. Lots of fine soldering. Invest in a good soldering iron and definitely a magnifying lamp. All the information that you will need to learn is on here and there is no substitute for reading, studying and doing it. It's tough getting easy repairable iPods from eBay since more and more of them are jailbroken and failed multiple attempts of repair by multiple people. So you never really know what you are getting. DO not forget to check your local pawn shops, craigslist etc. of course that depends on your geographical location. Personally I like the older iPods, easier to repair and not to many people messing with those since the profit margin is way less. Ipod and iPhone repair can get pretty intense as you will find out by reading through some of the questions. Good luck and do not hesitate to ask, there are some very knowledgeable people on here that are always helpful.
完成的
+ upvote, just for the sheer effort
完成的
Here is a link to a video that gives you an idea what you are looking at. The video is a 2nd gen so this is just for information. The connector that you need is available here but I am sure you can find it cheaper by looking a little better then I just did
完成的
添加一条评论
Turn your iPod off
michelle, April 9, 2011
Tristan, April 9, 2011
also, after you reinstall, you can watch this video for additional help: http://www.youtube.com/watch?v=5uT8Utk5T...
michelle, April 10, 2011
Show 2 more comments
这个答案有帮助吗?
得分 3
添加一条评论
I'm posting this because I've tried everything to to fix my iPod 5. When its turned on the same message comes up, "iPod is disabled connect to iTunes." When I connected it it said "iPod... is disabled... to connect to iTunes input password on iPod..."
Thing is the iPod wouldn't let me put in a password... -__-
LONG STORY SHORT I downloaded Tenorshare ReiBoot on my mac to force a reboot and it actually worked!
The only thing is you need to know the iTunes account and password that was originally used to set up the iPod/iPhone/iPad.
I don't believe anything else works.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
michelle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 32
过去 30 天: 111
总计 253,601
