跳转到主内容
The HP Officejet Pro 6835 is an ink printer that has a built in scanner and copier. Pages can be printed directly via USB connection or over WiFi. The printer can be identified by its model number: J2D37A
Help bypass Code Ox6100004a
I have a code on my printer that reads paper jam or repair/replace ink. I replaced all ink, checked all paper access points. No jam and full of ink. Code still remains. Any info would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Perhaps the following post will help:
"There is a problem with the printer or ink system"
Seems to be exactly the same problem you are seeing. Be sure to read all of the comments/replies.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
butlercanecorso 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 953
