跳转到主内容
加入维修社区 - 创建账户
Orange light keeps blinking
Does the ipod charge even if the orange light is blinking?I restored it!still the same problem!!can somebody help?i can transfer music and it gets detected too!!just that the light keeps on blinkin!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Ash, check on here http://support.apple.com/kb/ht1407 . It looks like the flashing orange = busy, either syncing or in use as a remote disk. If you check the manual on page 19 it tells you how to enable it, or in your case, disable it. I wonder if the orange lights will stop if you disable it as a remote disk. Here is the manuals.info.apple.com/en/ipod_shuffle_features_guide.pdf''italic text''
To enable iPod shuffle as an external disk:
1 Connect iPod shuffle to your computer.
2 In iTunes, select iPod shuffle in the Source pane.
3 Click the Settings tab.
4 In the Options section, select “Enable disk use.”
Note: You may need to scroll down to see the disk settings.
5 Adjust the slider to set how much space to reserve for songs versus data.
6 Click Apply.
When you use iPod shuffle as an external disk, the iPod shuffle disk icon appears on the desktop on the Mac, or as the next available drive letter in Windows Explorer on a Windows PC. There is also more info right here Good Luck and let us know if it works
这个答案有帮助吗?
得分 3
添加一条评论
Eject it from iTunes, then eject it from the computer as well. Leave it plugged in and it should charge, and the orange light will stay on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 34
总计 38,197
