跳转到主内容
加入维修社区 - 创建账户
Skullcandy Hesh 2 是一款由 Skullcandy 公司销售的蓝牙无线包耳式耳机。你可以通过型号 S6HBGY-3xx 来识别 Skullcandy Hesh 2。
No sound in one speaker
The sound in one of my headphone's speakers is rather faint and sometimes completely absent. I think it might be a internal wiring issue or a faulty speaker. Is there any way I might be able to repair or replace the speaker myself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
@rhatten5 you need to check the wiring to the speaker that is not working properly. Depending on which side, it may be the crossover cable or the wiring right on the speaker. Yes you can replace it but you need to find a replacement which is not always easy. At this point I would check the wiring first. Post some images of what your speakers etc. Look like so we can see what you see. 在已经存在的问题里加入图片
Check this video to get to your speakers etc.
Use a multimeter and check to see if there is continuity from the plug/board to your speaker. If not then it is the crossover cable. If there is then the issue is with/on the speaker.
这个答案有帮助吗?
得分 1
4条评论:
when i connect my hesh 2 headset on aux cable i get sound on both ears, but when i connect on bluetooth i get sound only on the left ear.. what is the issue.. plz help fixit
完成的
I have the same issue.
完成的
I also have this same issue with my Skullcandy hesh2
完成的
I too :/ help please
完成的
添加一条评论
添加你的答案
Ryan Hatten 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 28
总计 4,218
