跳转到主内容
加入维修社区 - 创建账户
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Home button still not working
So i have swapped many screen and so lastly put in an ifixit replacement home button and it still doesn’t recognize it. So could the be a part that burnt out when this one was destroyed by unknown forces ? I hate to just use the five finger gesture or digital home button. Which means the on/off button will have to be used to wake it up. Going to give it away as was the purpose of buying it anway but would like to know if there is a fix. Thabks for everyones help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It's possible you received a defective replacement Home button. Barring that, you need to double check the condition of the flex cable on the button and the condition of the connector on the logic board. You'll also want to closely inspect the components in the area surrounding the connectors as they can sometimes get dislodged when prying the connectors off. If either of these are damaged, it would impede the proper function of the home button.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Perry Green 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 31
总计 146
