跳转到主内容
加入维修社区 - 创建账户
旨在缓慢移动并完成大型工作的机器的维修指南,包括专为特殊任务设计的农用车辆和建筑车辆。
Manual PTO not engaging blades
Hello - I have a White Outdoor LT-1650 tractor. When the tractor has been running for 15 mins or longer, the manual PTO will not engage the blades. I replaced the belt and spring thinking they may have become stretched out. This didn’t solve the problem. The engine pulley is spinning fine. When I turn the PTO lever, the pulley pushed out fine. It just doesn’t seem to be putting enough pressure on the belt. I can’t find any other adjustments that would solve this issue. Any help would be great.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@mjones21 besides checking the idler pulley you also need to check the routing of the belt, the connection of the springs, the engine pulley and the pulley's on the deck. Make sure that all of those are in working order, not seized etc.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
You have an idler pulley that has moved out of place or is seperated/seperating. Very careful inspection will tell you. Look for NEW wear marks on pulleys. Check springs too. Good luck
这个答案有帮助吗?
得分 2
1条评论:
Inspect the manual PTO lever, if it rests mid way when disengaged it may have become bent. Replacing lever may be necessary for proper operation.
由完成的
添加一条评论
添加你的答案
Mark Jone 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 2,798
