跳转到主内容
The Dell Latitude E6400 was Dell's mainstream corporate 14.1" notebook introduced in August 2008.
Activating the Bluetooth wireless switch
I have been trying to tether my iPhone to my Dell Latitude E6400 using Bluetooth. When I click on the Bluetooth icon, it tells me to activate the wireless switch. How do I do this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 57
18条评论
i have switched on the airplane mode so it stops all wireless connection,bluetooth...but i cant to off it i tried all known possiblities fn+signal symbol,setting al is greyed out
完成的
hello guys I'm here to help you guys
please update the drivers
and please refer the following link just copy and paste on the browser after downloading you can use Bluetooth and also can view in device manager
http://www.driverscape.com/manufacturers...
完成的
How can I instail my bluetooth?
完成的
I have dell latitude e6400 Laptop and having problrm with blutooth.. bluetooth indicater light is on but there in no any bluetooth icon anywhere in the laptop in divice manager or control panel etc
完成的
mine too
please help
完成的
显示更多的13条评论
添加一条评论
5个答案
已选择的解决方案
First, be sure you have the Bluetooth option; it is not standard equipment on your model. You should have a Bluetooth indicator light above the F1 key if yours came equipped with Bluetooth. There should be a key sequence marked for it on the keyboard. I believe it is Fn+F2 that will switch your Bluetooth wireless on and off. Your WiFi wireless switch is on the right, above the headphone and microphone ports (next to "Dell Wi-Fi Catcher" button).
这个答案有帮助吗?
得分 40
14条评论:
Good answer.....+
完成的
Thank You. It is working now
完成的
still cant find it
完成的
still bluetooth indicator light above F1 not on..
plz help me..
完成的
my light will not come on iv pressed fn+f2 as well
完成的
显示更多的9条评论
添加一条评论
Turn on your wireless from wireless button and bluetooth will also turn on with this.
这个答案有帮助吗?
得分 15
1条评论:
Vergo, read the comment made by Kevin McConnell (the OP), March 23, 2011. Good answer to a very old and resolved question
完成的
添加一条评论
Firstly you need to make sure that whether your Bluetooth is properly installed and as far as the switch is concerned the check on you keyboard from F1 to F12 where you can see the Bluetooth icon. So all you need to do is just to press Fn key and then hold the exact Bluetooth activating key.
这个答案有帮助吗?
得分 2
1条评论:
bluetooth is not turning on in my laptop
完成的
添加一条评论
you may not have the bluetooth driver installed. Go to dell support, look up the 370 minicard under wireless devices, and download that driver. Once it's installed you will have the tray icon where you can connect your bluetooth device. Here is a link:
http://www.dell.com/support/home/us/en/1...
这个答案有帮助吗?
得分 1
2条评论:
I have a Dell latitude e6430, and it did not come with a Bluetooth card. There isn't a Bluetooth symbol on my keyboard anywhere can I install one? And if I can will a Bluetooth card from a Dell Latitude 6400 be compatible?
完成的
You can always install a USB dongle to add Bluetooth functionality. And yes, they make WiFi cards that include Bluetooth so that is also possible. I'd go for a newer one since the lat e6400 is like 10 yrs old
完成的
添加一条评论
i have a dell e6400 the blue bluetooth icon is on, bluetooth card is in, i have windows 10 i cannot find bluetooth software please help this is extremely fustrating
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin McConnell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 60
总计 265,070
