跳转到主内容
加入维修社区 - 创建账户
第二代车型(底盘型号 L30)为北美市场专属版本,同样由 Nissan 加州设计中心在 Doug Wilson 的带领下设计,设计工作持续到 1994 年(1995 年设计定型)。
P1105 code is not going away
I've replaced map sensor, code still shows. What's the issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@smooch a failed MAP/Baro Switch solenoid can give you the same code. Check for more reasons for code P1105 on here If that solenoid does not open then your sensor does not get a vacuum and will read barometric pressure which will trigger this code. Check the solenoid by unplugging the vacuum hose on the sensor and attach a vacuum gauge to that. Start your car and within seconds your gauge should read a vacuum. If there is no vacuum then it is most likely that your solenoid has failed. Of course this will only work if your vacuum hoses are not cracked etc.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Quinton Higgins 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 43
总计 5,066
