跳转到主内容
加入维修社区 - 创建账户
型号 A1502 / 2.6 GHz(睿频最高可达 3.1 GHz)或 2.8 GHz(睿频最高可达 3.3 GHz)双核 Intel Core i7 处理器,配备 4MB 共享三级缓存。
Flashing question mark folder
Have a mid 2014 A1502 MacBook Pro 13”. Power it on. Give it a few seconds a flashing question mark folder flashes. Went online and found the cause of it. Did hold option while powering up. Hard drive didn’t pop up. So powered off. Tried command and r. That worked to start repair utilities. Went to utilities to find my hard drive to restore it wasn’t there. All videos and replies state that it’s the hard drive cable. Went online to find it,there’s are no hard drive cable for my model Mac. So how to fix?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
4个答案
已选择的解决方案
Well the video's you've found are for the older non-retina models which us a spinning hard drive. Unlike them your system uses a solid state SSD which plugs directly onto the logic board (no ribbon cable)
Sadly, it sounds like your SSD drive has died. At this point you'll need to replace it with a new drive. Here's the IFIXIT guide to get to it: MacBook Pro 13" Retina 显示屏 2014中期 SSD 更换 Here's one source MacBook Air 11" (2013-2015) 13" (2013-2017) MacBook Pro Retina 13" and 15" (2015) SSD Or, if you are looking for something larger check out Transcend - JetDrive 820 or OWC - Aura Pro X
Replace or upgrade your solid-state drive.图片
产品
$39.99
这个答案有帮助吗?
得分 2
添加一条评论
My macbook was okay after I opened it while holding ALT+CMD+P+R, and this apple support page explains how to do this procedure : https://support.apple.com/en-ca/HT204063
That was it for me, they told me it was because I didn't turn off my computer often enough...
So if you haven't tried it, it can't hurt. If it doesn't work, then you can move on to another explanation...
Hope your computer is ok!
这个答案有帮助吗?
得分 2
1条评论:
Worked for me amazing thank you
由完成的 分享
添加一条评论
I did fix the mac by replacing the ssd and reinstalling Catalina. with an external ssd one. J also managed to backup the mac before and didn’t loose my shiet. Every now and then when i pressed alt and power to select where to boot from. I could see the mackintosh hard drive and i could boot from there but it always unmount within 30 minutes. This ssd externally tho caused other issues like i had problems with the wifi and apparently it was the side of the usb the ssd was on. It should always be on the left cause the left is more powerful. Took me 2 days to solve that one but i made it
这个答案有帮助吗?
得分 1
1条评论:
Thank you Angela. This will be my last option. I already tried with one external ssd and it worked.
由完成的 分享
添加一条评论
Nope! Changing the ssd didnt solve anything. Still flashing folder.
这个答案有帮助吗?
得分 0
9条评论:
Well, there's not much beside a possible faulty flash drive. If it's not the drive, then it's the logic board that either needs to be replaced or repaired.
由完成的 分享
Did you install a fresh copy of MacOS onto it? A new drive needs to be formatted and have the OS installed.
Restart your system and hold the Option, ⌘ and R Keys to enter into Internet recovery.
References:
● How to reinstall macOS from macOS Recovery
● About macOS Recovery
● Mac startup key combinations
由完成的 分享
Angela stavrinou
@ninaki did you solved your problem? I have the same one. Changed the ssd and the problem remains. Any hellppp?? And yes, I installed the MacOs again.
Thank you!!
由完成的 分享
Boot up under the recovery partition or external drive (reference the startup link above). Check the preference setting Startup Disk. Is it pointing to the correct drive?
由完成的 分享
@danj My problem is that the mac does not recognize the ssd. Sometimes yes, and sometimes no. In the apple support they told me that it was the ssd and that I lost everything cause it was all damaged. Even that, I've been capable of saving everything because the mac recogized again the ssd. After that I changed the sdd but the problem still remains. Sometimes the mac recognize the disk and I reinstall the Macos and everything seems fine. But then, stops working and does not recognize the ssd again. I'm so sad cause I never had any problem with the pc, and he used to work so well. now it seems that I have to buy a new one.
Thank you for your answer anyway!
由完成的 分享
显示更多的4条评论
添加一条评论
添加你的答案
allandz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 49
总计 30,326
