跳转到主内容
加入维修社区 - 创建账户
Xbox 360 是微软于2005年11月22日推出的第二代电视游戏主机。
Repairing firmware
Do we have anyone with experience in repairing firmware? I have disassembled many, replaced bad drives or ports, etc. I am looking for any Xbox 360 lessons-learned, knowledge, help hints, and any information on "bricking" and "unbricking".
Your assistance is greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
7个答案
已选择的解决方案
1 Red Ring is a general error
2 Red Rings is overheating
3 Red Rings is hardware failure (ususally a bad joint between the GPU and Logic Board)
error codes are ususally not easy to fix, there are error code keys on the web, but there are tons of error codes.
这个答案有帮助吗?
得分 2
1条评论:
Lazer setting off.YouTube it.easy fix.
完成的
添加一条评论
最有帮助的答案
ususally, xbox's don't get bricked, they have onboard firmware, and the firmware is not accessable externally, if you are trying to remove the NXE, it isn't possible, if you want to try, you may be able to trick the console into downgrading the firmware, by putting a firmware update file on the hard drive via special adaptor, but annother thing to know is that the xbox dvd drives are keyed to the motherboard that they shipped with, so if you get a new logic board, make sure that it comes with a DVD Drive
这个答案有帮助吗?
得分 3
1条评论:
Thank you very much for the information...I wondered if they were keyed. Any info on red rings (1-3), error codes, and RROD. I am still learning. Thanks, Kelly
完成的
添加一条评论
i found this really helpful.
http://www.llamma.com/xbox360/repair/Xbo...
这个答案有帮助吗?
得分 3
1条评论:
Lots of good stuff here. +
完成的
添加一条评论
These are the ones I use whenever I get to tinker with an XBox or just to keep mine alive. I do like xbins since it does have the proper software for remapping as well as firmware issues. Comes in handy....good luck.
这个答案有帮助吗?
得分 1
1条评论:
Sorry forgot a few things :) http://www.xbins.org/
http://www.360-hq.com/xbox360/hardware/ that is what I meant to attach...
完成的
添加一条评论
ok,my xbox360 starts screen freezes. scanable look. but with out hardrive it run disc fine. if idea.
这个答案有帮助吗?
得分 1
1条评论:
HDD Problem, try replacing it.
完成的
添加一条评论
Hi Anibal my Xbox 360 not how open work happen know not
这个答案有帮助吗?
得分 0
添加一条评论
Not work open each much time Xbox 360
这个答案有帮助吗?
得分 0
1条评论:
Not work Xbox 360 open not
完成的
添加一条评论
添加你的答案
aquabluekt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 6,619
