跳转到主内容
The Dell Inspiron 14-7437 is pre-installed with Windows 8, has 4th generation Intel Core processors and a 14-inch display.
My laptop is not charging, help!
Hi,
My laptop stopped charging recently. It works when plugged in but says "1%, not charging. Power mode (plugged in)." My first response was buying a new charger but the same thing happened. So I thought it must be the power jack. I ordered one on ebay and replaced it today. But the same thing happened - 1%, not charging...help! What else could it be?
Thanks Magda
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Hi @magbrown? had you checked about the battery?
完成的
what are you doing while you have this issue? you doing anything resource intensive?
完成的
No, not at all. I’m just simply using my laptop whilst pugged in. When I unplug it the laptop imediatelly turns itself off :( Thanks
完成的
添加一条评论
1个答案
Try replacing the battery, and/or the pins and cables connecting the battery to the power jack and motherboard.
这个答案有帮助吗?
得分 0
1条评论:
The laptop is only two years old. Do you think it could be the battery? Thanks :)
完成的
添加一条评论
添加你的答案
Magdalena Browning 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 335
