跳转到主内容
加入维修社区 - 创建账户
Roomba 650 是 iRobot 于 2012 年 8 月发布的一款第四代扫地机器人。该设备无需动手,可通过编程实现自动清扫居家环境。它几乎不需要手动操作,彻底改变了家庭清洁方式。
Not charging/functioning after getting base wet
Good afternoon,
Had an unfortunate run in between my iRoomba, the tile floor, and my dog who couldn't hold in her bowels. Post-event, I attempted to clean the bot manually with water and dilute cleaning solution. The unit (650) now does not seem to be able to turn on/charge. Can you please advise on how I can troubleshoot to find the problem? Thank you for your time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@brettvet hope your dog is okay. Anyhow, you do need to disassemble your Roomba further and clean everything with 90%+ isopropyl alcohol. Besides cleaning things, it will also displace the water. Since you are dealing with electronics and a battery, try not to use to much water other than on the plastic parts maybe. Anyhow, start with these guides iRobot Roomba 650 to work on it. After it is cleaned you most likely want to get a new battery and then re-evaluate your Roomba.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brett Harling 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 20
过去 30 天: 37
总计 4,958
