cracked look in screen
my laptop has a layer that looks cracked not top layer it was leaned on
So your glass is okay but your LCD is cracked? Time to get a new display they are relative inexpensive http://www.lcdscreen.com/ppc-series-acer...
这个答案有帮助吗?
If you are not planning on replacing an LCD connect an external monitor using a VGA cable for output or if your TV has a VGA connector then you can even get the output on your TV.
You can buy a replacement LCD from eBay and take it to a local electrician and have it replaced for you
Good Luck.
这个答案有帮助吗?
Hopefully the OP fixed it within the last 2 years ;-)
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 2,106
