跳转到主内容
加入维修社区 - 创建账户
这是一款小型媒体流媒体播放设备,可直接插入电视的 HDMI 接口。由 Amazon 于 2014 年 11 月首次发布。最新版本配有语音控制遥控器。
Freezing, Buffering Fire Stick Help
Have Direct TV app (beta, for the DVR), use a Fire Stick. once an hour or so the app goes to buffering - we restart the App, reset the modem, restart the fire stick - nothing seems to make it work. We have cleared the cache. Still buffering and other hijinks. What else can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
if you have fire stick issues then read my blog here http://www.teqguru.com/amazon-fire-stick...
由完成的
添加一条评论
6个答案
最有帮助的答案
Buy Ethernet adaptor and then connect to your router directly NO MORE STUTTERING…its your wi fi signal not the fire stick which is problem…
这个答案有帮助吗?
得分 3
1条评论:
Well it is not always convenient but still it is efficient and a good way to troubleshoot.
由完成的
添加一条评论
reset your data then go back to the app you will have to redo your password and settings and its a pain in the ass
这个答案有帮助吗?
得分 2
添加一条评论
This is all BS. Please cancel my service including prime until you can provide the service I purchased.
这个答案有帮助吗?
得分 1
添加一条评论
On thing to do if you have not done it is get rid of the 1 watt power supply and use a 2 watt one. That will cure buffering altogether period!
Enjoy and stop by www.rondoids.com for some news stories.
Ron
这个答案有帮助吗?
得分 1
6条评论:
Would I just buy a more powerful plugin? What did you do exactly to go from 1 watt to 2 watt power supply? Where did you get new power supply?
由完成的
My standard Amazon power supply is 9w ???
由完成的
Firestick keeps sticking even when i clear all the cache on all the apps i have.
What else is there you can do to fix the problem. I have a 4k firestick.
由完成的
I guess he meant 2amps instead of one. 9W is 1.8amps and is the recommended spec. 10W is also OK.
由完成的
Interesting. looping z thanks for learing that up. I would have been driven mad otherwise thinking it wax just me making it harder to follow diredctions lol
由完成的
显示更多的1条评论
添加一条评论
Suggestions.
a) Get a faster model. If you have a first generation Fire stick (without the mic remote), this is a very slow stick to being with.
b) Wait for direct tv to release an updated app (complain to amazon to encourage this)
c) If you're Wi-Fi is built into your Internet modem, get a separate Wi-Fi router. It is a well proven fact that all-in-one Router/Modems have poor and unreliable Wi-Fi performance. You should be connecting to the faster 5ghz frequency on the Wi-Fi router.
这个答案有帮助吗?
得分 0
1条评论:
I don't want this service for any price if I can't see a full movie with the equipment I already own. It should be part of your disclaimer if you can't provide the service as advertised.
由完成的
添加一条评论
Mostly when we use Fire tv stick, might come across in streaming problems. Sometimes, we might encounter the streaming issue because of the incompatible internet connection which includes slow speed or intermittent connectivity. Here I will discuss about resetting the router that help me to a great extent. So, do this like as:
1. Look for a tiny reset hole on your router. It will be on the back side.
2. Use a tiny pin or paper clip to insert to the reset hole and hold it there for 10 seconds.
3. Take the Pinout and wait until the light indicators are started glowing.
Besides, to fix fire tv streaming issues , try these things:
- Clear the Amazon Video application Cache
- Clearing Data for other Video Apps
- Deregister & re-register the Fire TV Stick
To fix streaming issues, you can use Ethernet Adapter.
这个答案有帮助吗?
得分 0
1条评论:
The firstick TV 4K version hasn't got an ethernet connection socket on it, so how can you connect your firestick TV into a none existent socket on the firestick?. Yes there's a ethernet spare socket on a modem/router okay, but not one on the firstick at all
由完成的
添加一条评论
添加你的答案
nhammond23 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 61,607
