跳转到主内容
加入维修社区 - 创建账户
随着 1999 年末推出的重新设计车型作为 2000 款上市,Sentra 终于跨入了“紧凑型”轿车行列。
RPM Drops to Zero while Driving
RPM Drops to Zero while Driving, releasing X-pedal and car slows down and RPM needle drops to Zero and car starts to Shake/Vibrate.
cleaned throttle body, air flow sensor, changed coil packs, no engine light comes on, changed speed sensor because of misfiring (not changing to 2nd gear).
Didnt service injectors yet, its a bit expensive .
please help me!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
I own such a car and model This malfunction is for the tps sensor and needs to be re-calibrated and the number is set on the computer number 48 for the automatic car and the number 46 for the vehicle The symptoms of this malfunction are what I mentioned in your question in addition to the violent switching of the gearbox there is a solution to re-calibrate and another solution is the work of Rest For the car computerIt is a temporary and effective solution, and the way to put the key and manage the car key without operating once the Airbag indicator has disappeared. Close the key as soon as you hear a computer click.Repeat the step again - then the third time turn the car engine - now the car computer has been restedطريقة عمل ريست لكمبيوتر السيارة نيسان صني n16
这个答案有帮助吗?
得分 0
添加一条评论
Une moteur
Il me taire
这个答案有帮助吗?
得分 0
1条评论:
Huile moteur
由完成的
添加一条评论
添加你的答案
Nex Gen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 32
总计 4,510
