跳转到主内容
加入维修社区 - 创建账户
V2000 是由 HP 以 Compaq 名义开发的 Compaq Presario 笔记本电脑。V2000 是 HP DV1000 的姐妹机型,因此二者共享许多功能和规格,尽管在 21 世纪初这两款机型销售时,DV1000 的价格大约高出 100 美元。
How can I autocheck the program?
how can i fix my compaq v2000 saying in the screen "autochk program not found-skipping AUTOCHECK?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try below:-
*Unplug the AC cord
*Remove the battery
*Locate the memory cover on the underside of the notebook
*Unscrew the one or two screws securing the memory cover, and lift up to remove the cover
*Gently slide (away from one another) the metal retaining clips that hold down the module.
*The module should pop up
*Remove the module
*Reinstall the module (removing and reinstalling the module is apparently enough to rectify the contacts)
*Replace the module cover and the battery
*Attach the power cord
*Try to power up
Hopefully, this works for you!!!!!!!!!
这个答案有帮助吗?
得分 0
1条评论:
its still not working id tried it.. but its still appearing on screen " autochk program not found-skipping autocheck
please help me guys thank u
由完成的
添加一条评论
Jaypi Liboon appears to be an OS issue. Let us know what OS you are using Win7 etc. Check for answers with Microsoft on here as well as on on here. the error seems to be related to either hidden partition or missing drive letters.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jaypi Liboon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 34
总计 365
