跳转到主内容
加入维修社区 - 创建账户
硬盘或机械硬盘的维修信息。硬盘是磁性数据存储设备。由于其成本低廉且数据密度高,它们被广泛应用于大多数台式机、笔记本电脑和服务器中。
Can HDDs operate upside down?
This may be stupid and obvious but, I have a hard drive that putting it in my desktop upside down would be better for cable management. would it work (reliably) upside down? it's probably a yes, but I'd rather not kill a perfectly good hard drive if not. (especially with data on it.)
@danj or @oldturkey03 I think you might know this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
It depends on the size and the age of the drive!
A 3.5" is designed to be mounted either on its side or flat with the top of the drive up. While you can run it upside down it's not something I would do as its normal position. In the case of older drives - I wouldn't alter the basic mounting. If you do mount it differently its a good idea to reformat the drive so any slop in the heads will not mis-write or read. Moving the system or banging the drive can crash the drive very easily when its running.
2.5" drives are less sensitive on it's mounting but just like 3.5" drives moving or banging the drive can crash it. most laptops have crash guard protection systems so the head assembly is parked before any damage when the system is banged when running.
In any case make sure the drive mounts are cushioned.
这个答案有帮助吗?
得分 5
41条评论:
In my dell the hard drives are upside down and they work fine.
由完成的
What is the size of the drive? I bet you its a 2.5"
If you replace it I would review the spec sheet of the drive you put in to see if it makes any note on mounting.
由完成的
@danj All Dell computers have drives either sideways or upside down on the business lines of computers. Only Ancient 3.5" may have had issues running upside down. Those were like ....10mb (not gb) hard drives. As a matter of fact, i still have one of those ancient Western digitals. You had to actually run a DOS command / program to park the hard drive head before turning off the computer.
由完成的
@avanteguarde - That was my point! A 2.5" drive wouldn't have as issue running upside down. Only the older 3.5" drives.
Even still its smart to format the drive and run it at the same direction so there is less risk of error from head slop.
由完成的
It has two 3.5. One original 80GB and one 2008 iMac 250GB hard drives.
由完成的
显示更多的36条评论
添加一条评论
最有帮助的答案
Yes, they can operate sideways, upside down, port side down etc.
这个答案有帮助吗?
得分 6
8条评论:
Thanks! I'm always paranoid with HDDs
由完成的
@avanteguarde one more thing... Is it OK for an HDD to be right under a DVD drive? I remember pulling apart a DVD player and finding a magnet inside.
由完成的
Yes, it is fine.
Hard drives are shielded. Just don't put a real magnet directly on the hard drive.
由完成的
@captainsnowball There is a strong magnet in hard drives too so it’s more than fine.
由完成的
I see where you're coming from, but that magnet is very tiny so it can not destroy the HDD.
由完成的
显示更多的3条评论
添加一条评论
Yep, you can have them up side down, perpendicular to the bottom of the case, at 45 degree angles are not recommended. The most important things are making sure they're secure and that their temps are cool enough.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aiden 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 97
总计 39,319
