跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
Dead iPod- NOT the battery
iPod won't turn on, regardless of whether or not it is plugged into anything. The battery life is still in really good shape and was fully charged at the time it stopped working. Had walked to work with it on, left it in pocket, took off coat, then took out iPod to use in an audio system and it wouldn't turn on. Seems improbable it could randomly die in 5 minutes...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
4条评论
It worked, oldturkey. Thank you for protecting me from my own karma.
完成的
Thank you for accepting my answer. Wishing you the best of luck and keep on jamming:-)
完成的
Thank You It worked never thought of the on off button i tried everything else
Thanks Again
完成的
Your instructions worked miraculously! I really thought I had lost it (and all my recordings) forever. THANK YOU!
完成的
添加一条评论
2个答案
已选择的解决方案
Yes, they can die from one minute to the next :-) Try to reset your iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
What happens when you plug it into your computer? If this does not work, you may have to take a closer look at it. Let us know how it is going. Good Luck
这个答案有帮助吗?
得分 20
32条评论:
Had same problem. Solution worked. Thank you very much.
完成的
awesome...problem solved...thanks
完成的
Nice. Thank you. Problem solved!
完成的
Thanks so much! worked perfectly
完成的
@Matt Tierney, you are welcome :)
完成的
显示更多的27条评论
添加一条评论
will I lose my tunes if I replace a dead hard drive on my apple iPod 5th generation
这个答案有帮助吗?
得分 0
1条评论:
Yea as this is where the "Tunes" are kept.
完成的
添加一条评论
添加你的答案
Danielle 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 50
总计 50,247
