跳转到主内容
加入维修社区 - 创建账户
Nokia 5130 XpressMusic 是诺基亚 XpressMusic 系列手机之一。它于 2009 年 1 月发布,并于 2011 年停产。
Contact Service Problem of nokia 5130
When i try to open my nokia 5130 mobile it shows a message --- 'contact service' on the screen. Then it becomes switch off.
How to fix this problem of my phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
5条评论
contact service problem on my mobile please give the solution..
Many thanks
由完成的 分享
packet data connection
由完成的 分享
my phone nokia 3100 is in contact service on the screen what shall i do??thanks
由完成的 分享
Sir my Nokia 3220 mobile when I switch ON the mobile a contact service is written on display .what I can do?
由完成的 分享
I have Nokia 130 contact service, would you tell about this post he is saying right. thank
post here. http://htfmobile.blogspot.com/2018/03/no...
由完成的 分享
添加一条评论
18个答案
已选择的解决方案
santanu, you could try to reset your phone
http://en.kioskea.net/faq/470-how-to-res...
1. *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data)
Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list. The default code for ALL operations listed here is 12345
2. *#7370# - Reformat your phone (out of the box, tho keep in mind that most newer nokia phones at least n series, e series and s60 based phones have udp - user data preservation so not ALL data may be lost. still it is a good idea to always do a back up of your stuff.)
3. This you perform as a last resort. Nothing else is working.If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button. (the default code is 12345)
hard reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons
http://discussions.europe.nokia.com/t5/O...
If none of this works you can also try to update your firmware. Download and install the latest Nokia Software Update and Nokia PC Suite, connect your phone, and run NSU. You will be prompted to update the firmware if a new version is available. Just make sure that you backup your phone since it will delete everything in th memory of your phone.
And if none of that works, you should definitely contact your cell service provider. Did you pay your bill :-)? Good Luck to you and let us know how it is going.
这个答案有帮助吗?
得分 7
3条评论:
The go to, menu and music options doesnt work. Help
由完成的 分享
i can forget my password i try *=3=green button= power buton but mobile doesnt reset
由完成的 分享
answer me
i am wating for ur rply
由完成的 分享
添加一条评论
when i try to open my nokia 5130 mobile it shows amessage-contact service on the screen. it becomes switch off.How to fix problem 0f my phone.
这个答案有帮助吗?
得分 4
添加一条评论
这个答案有帮助吗?
得分 2
1条评论:
Roy, have you tried any of the above answers?
由完成的 分享
添加一条评论
contact service problem restart
这个答案有帮助吗?
得分 2
添加一条评论
when itry to open my nokia 5130 mobile it shows a message-contact service on the screen. it becomes switch off. How to fix problem of my phone.
Update
how to fix my problem.
这个答案有帮助吗?
得分 2
1条评论:
service provider is needed
由完成的 分享
添加一条评论
Maybe you should contact service?
这个答案有帮助吗?
得分 1
添加一条评论
Can be defective UEM IC..
这个答案有帮助吗?
得分 1
添加一条评论
nokia 5130 contant servic ke bad band
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
i think there is hardeware problem, motherboard problem, and it will be fixed after changing of motherboard..
这个答案有帮助吗?
得分 0
添加一条评论
contak servesفحص المشكلة
这个答案有帮助吗?
得分 0
添加一条评论
pls help my nokia 5130 error contct service problem then on mobile after contact service off
这个答案有帮助吗?
得分 0
添加一条评论
jab mai koi work nahi karta hu mobile par toh wo automatic switched off ho jata hai.....please reply
这个答案有帮助吗?
得分 0
添加一条评论
*#7782#
这个答案有帮助吗?
得分 0
添加一条评论
عندما افتح الهاتفنوكيا xpressmusic5130 تضهر رسالة تقول كونطاكت سيرفس
这个答案有帮助吗?
得分 0
添加一条评论
my hp, just live with the error tuliisan "nokia" just ...? whether the damaged ... and serial number while still living a beautiful number ...? ask for the explanation ... thanks
这个答案有帮助吗?
得分 0
添加一条评论
contant sarvic ke bad off
这个答案有帮助吗?
得分 0
添加一条评论
== Heading text
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
santanu 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 56
总计 100,505
