跳转到主内容
加入维修社区 - 创建账户
一款由联想生产的笔记本电脑,在世界各地的办公室中非常常见。
Laptop to desktop project
I've got a lenovo thinkpad t410 with a serious overheating problem. I'd like to turn it into a custom desktop for a fun project. Instead of using the included fan, I want to use a large aluminum heat sink from an old desktop, with another fan directed up through it. However, the thinkpad will shut down without the original fan and heat sink in it's proper place. Does anyone know of a way to disable this function to allow me to proceed with this project?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@anathem0 not quite sure what your setup currently looks like., You should consider posting plenty of images so we can see what you see. 在已经存在的问题里加入图片 How do you have the replacement heatsink and fan connected? Any chance you could connect that fan to the T410 motherboard?
由完成的
I seem to have located the issue. I believe that the problem was that heat was not being drawn away from the chips fast enough and the system detected this and shut down. A simple application of some thermal paste seems to have fixed the problem. In addition to the aluminum heat sink and the correct application of thermal paste, I will be re-utilizing the original fan to circulate air through the build. When it's done, I'll post some pictures!
由完成的
添加一条评论
1个答案
已选择的解决方案
It may be that it's shutting down as a precautionary measure having detected that the original fan isn't connected. If you remove the fan from the original heat sink and cooling fins you can maybe plug it in just as an experiment.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Samuel Bennett 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 609
