跳转到主内容
Canon's Rebel XT is one of Canon's early entry-level DSLR's with an 8 MP sensor. Also known as the EOS 350D and the EOS Kiss Digital N.
20 个问题 查看全部
CF card error message
I've been having this CF card error message on my 350D pop up each time i try to use it.
I had a root around, and I believe the problem is a bent card reader pin inside the system itself.
Is this repairable? if so, how much, if it isnt a home fix.
thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I just repaired this on my 350d. Unfortunately the CF card reader pins are individually soldered to the main board so you can't just replace the bent ones, you have to replace the entire main board. I got a replacement board using a donor camera I got off ebay - the donor camera was spares/repairs due to terrible physical condition and a smashed lcd display glass but did just about work as a camera so the main board was intact. This cost me £30 but after swapping the boards between the donor and my own 350d I should be able to get around £20 back reselling the donor on ebay as bad condition and cf error.
I'll find the websites I used for teardown instructions, it's not a particularly difficult fix just a little fiddly at times. If you attempt it and need any help at any point I'm happy to help as I did it myself so recently it's fresh in my mind.
这个答案有帮助吗?
得分 2
1条评论:
Here are the links I remember using:
http://www.12dstring.me.uk/350dmod.htm - this is the best one, I only used the others to fill in the gaps/double check on things. It is actually telling you how to replace the filter for astrophotography but make sure you stop at the point where you remove the main board, don't go further pulling your sensor apart xD.
The other sites:
https://www.google.fr/url?sa=t&rct=j&q=&...
完成的
添加一条评论
添加你的答案
Ashley Mark Dorey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 2,697
