跳转到主内容
加入维修社区 - 创建账户
于 2016 年 3 月由 Samsung 发布。型号 SM-G930, 版本:G930F(全球版);G930FD(全球版;东南亚);G930W8(加拿大)。
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
1条评论
this is lwky a good question, I have the same problem, my best friend gave me her old Samsung Galaxy s7, and she kinda just gave me the password and got tfo so I looked up a ton of shi and the FRP lock is genuinely killing my soul right nowwwww.
由完成的
添加一条评论
3个答案
最有帮助的答案
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
这个答案有帮助吗?
得分 3
7条评论:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
由完成的
adb shell dumpsys iphonesubinfo
由完成的
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
由完成的
Removed comment.
由完成的
显示更多的2条评论
添加一条评论
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
这个答案有帮助吗?
得分 1
1条评论:
Should the phone be off or on ?
由完成的
添加一条评论
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 12,957
