跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
最有帮助的答案
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
这个答案有帮助吗?
得分 2
7条评论:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
完成的
adb shell dumpsys iphonesubinfo
完成的
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
完成的
Removed comment.
完成的
显示更多的2条评论
添加一条评论
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
这个答案有帮助吗?
得分 1
1条评论:
Should the phone be off or on ?
完成的
添加一条评论
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 29
过去 30 天: 93
总计 11,036
