跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
Screen freezes and pixilates.
My original 360 will turn on, but after about three to five minutes, it will completely seize up, and there is an aweful buzzing noise coming from my speakers. The screen also becomes distorted with lines running through it. If Anyone can help I would be appreciative, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
it sounds like you are on the fast track to getting rrod.
They sell a fix kit Here you might want to try. And a guide for it here. Hope all goes well.
Good Luck,
Cody
Xbox 360 Red Ring of Death Fix Kit图片
产品
$29.99
这个答案有帮助吗?
得分 1
1条评论:
+ agree with Cody on that one.
完成的
添加一条评论
That fix is not permanent. In fact, not even a reball with leaded solder is permanent, albeit it's the longest-lasting solution.
This method is basically just forcing the motherboard to warp so that the broken solder joints under the GPU touch.
A reflow of the GPU is a way better fix. Most people charge $35-40 for this on craigslist. Make sure they use a real reflow station with a real preheater and not a heatgun with electric griddle.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
corbin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 3,943
