跳转到主内容
加入维修社区 - 创建账户
Acer Aspire V3-771G 笔记本电脑。这是 Acer 提供的 17.3 英寸屏幕系列产品的一部分。
I have problem in the screen
I have laptop Acer V3-771 and i have problem in monitor :
The problem is : the output for the screen is white color.
I wont solve for this problem .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you very much for your advice
完成的
添加一条评论
1个答案
最有帮助的答案
@qutaiba72white screen means that the backlight is on but your display does not receive any data. Check with an external monitor and see if that displays properly. If it does, you know that you GPU is circuitry is working. Check the cable to your LCD and you may have to replace the LCD. If it does not then your issue is with the GPU so you will have to check on the motherboard. For that you would need the schematic
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Qutaiba Saoor 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 9
过去 30 天: 15
总计 502
