跳转到主内容
加入维修社区 - 创建账户
Chromo Noria 是一款搭载 Android 4.4 KitKat 操作系统的 7 英寸安卓平板电脑。它有黑色、蓝色、粉色和白色可选。
What SD card does of take
Will not go past the chrome screen need a SD card what kind
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@bobrien Chromo's use Micro-SD card. Not sure so how this will help your frozen screen. you do want to go ahead and backup all your personal files (pictures, music etc. ) and subsequently try a hard reset to restore it to factory defaults. This will erase all of your files as well as all of your settings. SO, make sure that you have all your email addresses and passwords that you need for a restore. Your tablet is a generic Android tablet, those usually do not have a standard way to Factory Reset. This should work for your Chromo:
Power off the tablet.
Press and hold both volume up and volume down key, while holding, press and hold the power button for a sec to turn it on.
Continue holding both power keys, once powered on the screen will go blank but it will be illuminated with a black screen.
Release volume keys and push volume up or down key to access recovery menu.
You can navigate the menu with vol keys. Use the power button to select the options
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brenda Obrien 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 364
