跳转到主内容
加入维修社区 - 创建账户
巴诺书店(Barnes & Noble)于 2011 年 11 月发布的 7 英寸多媒体平板电脑。维修简单,只需使用简单的撬具和螺丝刀即可完成。
Bottom row of keyboard is not responding
How can I fix this problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
pheobe Brown if it is just the keyboard that is not responding in that area, you could try a hard reset. If nothing responds at that area, you may be looking at a bad digitizer. For the hard reset try this
Confirm the device is powered off.
Hold the Power and Home key simultaneously.
Release the Power and Home key once the NOOK logo appears. A Factory Reset prompt will appear.
To continue, press the Home key.
To exit, press the Power key.
To change the digitizer you will have to disassemble your Nook. Use these guides for that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pheobe Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 2,400
