跳转到主内容
The Dell Inspiron 15R 5520 laptop features a 14.88" screen, brushed aluminum finish and features a i5 core processor .
12 个问题 查看全部
Broken Headphone jack. Is it fixable>
Long story short, I broke my headphone jack on my Dell Inspiron 5520 a while ago and today was the last straw. Is it possible to replace the entire jack without doing and soldering? Here's the part and I dont know if it just sits in place or if it requires soldering.
https://www.aliexpress.com/item/Audio-Ja...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
The broken headphone jack needs to de-soldered from the motherboard and replaced with the new one, that needs to be soldered back on. At the same time you need to use a special soldering iron (or a very good one) to melt the solder. Also, laptop boards are very complex and usually multi-layered, therefore using a soldering iron could break some traces or parts on the other side with no visible damage, aggravating the problem. A more elegant solution would be replacing the entire board or even taking it to a computer repair shop.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Desmond Waters 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 348
