跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 11-3147 是一款 11 英寸的笔记本电脑与平板二合一设备。其显示屏可以向后折叠,从而实现手持式使用。它由 Dell 于 2015 年 8 月制造。
Three beeps upon startup
Does not boot and instead get three beeps. Given three different possible solutions: Chipset Error (North and South bridge error)
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller failure
How would I go about testing which one of those would be causing the issue? The website says to run Dell's diagnostics tool but it won't even boot up far enough for me to access that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@inlerah start by removing the battery, the AC adapter and the RAM then hold the power button down for a while. Replace the AC adapter and see if it starts up. You also want to try a USB keyboard and see if that makes a difference. If not then I would suggest that you replace the RTC battery first and try to start it up after that. Use this guide Dell Inspiron 11-3147 CMOS 电池更换 for that.
Any of this
Gate A20 failure
would require boardlevel repair and for that you need to let us know what exact motherboard your computer has.
Update (10/21/2017)
@inlerah have you tried a different memory module? You do want to rule out that you have a bad module. Your motherboard should have a few numbers silk screened on the board. Just give us those numbers or post some really good pictures of your board with your question. You can use this guide 在已经存在的问题里加入图片 to do so.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Dell Inspiron 11-3147 CMOS 电池图片
指南
难度:
简单
10 minutes
这个答案有帮助吗?
得分 2
1条评论:
(Late response, had to wait until drivers of the right size got delivered) So I did this and I got back a "No ram detected" beep code. Where should I be going from here?
Also, I can get you the motherboard type...just need to know where to get that info from.
由完成的
添加一条评论
添加你的答案
William C Ward 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 18
总计 853
