跳转到主内容
加入维修社区 - 创建账户
Brother MFC-3240C 是一款五合一彩色喷墨打印机。
Random error code problems?
When I first got my printer off of Craigslist it read Unable to Clean. I cleared that up by resetting purge to all zeroes and cleaning out the ink absorber box. While I was setting all other settings to all zeroes. I think I should have stopped at zeroing just purge. Since then I've had error 50,error 46,36,Unable to Init., and now somehow it now reading Unable to print. I think (remember I said THINK) if I could reset all the default factory settings it would start working corectly. I'd be eternally grateful if someone could help me resolve this problem. I'm trying to fix this printer for an older woman in my building !
Thanks, Ronnie
P.S. There are no paper fragments or foreign objects in this prinetr !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Press Menu,*,2,8,6,4 (must be done inside two seconds). It should say
maintenance in the display after a short delay.
press 01 (to reset the EEPROM data), then 99 (to exit maintenance mode).
This will reset the EEPROM data
Brother Maintenance Mode Code
这个答案有帮助吗?
得分 2
1条评论:
I have the same problem with the error. It happened after a few ink refills. It seemed the ink was running out in the printer. I am gonna try this fix and see if it works for me
由完成的 分享
添加一条评论
It usually happens because of poor contact between cartridge and holders ans usually happens because of extra ink spilled over. So all you need to do is to clean out the head contacts by using some alcohol swabs or c2c solution.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ronald Massey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,348
