跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
20 个问题 查看全部
The keyboard fell into the juice
After the juice is dried Question mark Insensitive How to clean the keyboard yourself
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
添加一条评论
3个答案
已选择的解决方案
You will need to replace the keyboard. Cleaning it will not do anything. However, this machine is very new so finding parts will be very hard.
这个答案有帮助吗?
得分 2
5条评论:
How long does it take to change the keyboard, about how much money?
完成的
I think I have seen these keyboards recently on AliExpress for ~80$USD. Might be able to get lucky with that one.
完成的
To the OP. Replacing the keyboards is a huge pain. I am a tech that does motherboard repair and I still don't do them unless I have to. It's just a big pain.
完成的
Is there a guide for doing that on this machine?
完成的
@mayer No sir. A teardown but doesn't show the painful task of lifting the backlight and clipping the 50 or so rivets.
完成的
添加一条评论
Try using USB keyboard.
这个答案有帮助吗?
得分 2
添加一条评论
I literally just fixed one of these with a coffee spill, I would not recommend a non-tech replacing this part. A keyboard replacement means you need to change the entire bottom part of your computer (minus the trackpad and logic-board). I was able to find the part at a steep $800 (my cost) not to mention the labor the swap it out. An external keyboard (props to Anna) is the easiest solution for now until the parts become cheaper.
这个答案有帮助吗?
得分 1
1条评论:
Just out of curiosity, have you tried sticking the keyboard in an ultrasonic cleaner? Probably nothing to lose. Either way, I would suppose the top case would be worth quite a pretty penny on eBay even if the keyboard needs to be changed...
How did you deal with the touch bar?
完成的
添加一条评论
添加你的答案
zxf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 251
