Will not move forward or reverse
Have a Craftsman ZT7000 zero turn riding mower. Used it two days ago, now it will not move forward or reverse. Starts great, blades engage, belts are tight, I am at a loss. The two "arms" feel very stiff when I push or pull on them.
7条评论
Have thus same problem several times a year with our Cub Cadet mower, I am at the point of paying people to NOT buy any mower with this feature!
由 varmstrong4447 完成的
Holy Molly.....IT WORKED!!!!!!!!!
We can't THANK YOU enough....we couldn't figure out why the tractor would NOT MOVE at all. It was the easiest trick EVER!!!!
由 Shore Girl 完成的
We found out the bearing on the clutch shaft was shot replaced it problem solved
由 crystalk60 完成的
My cub cadet will go in reverse but not forward. It's got a new transmission and when it's jacked up the forward works. I noticed that the pully and fans stop moving on the transmission when trying to go forward. I have checked everything that was listed.
由 Daniel Wilson 完成的
I don't see those levers on mine
由 Lynn Graham 完成的
显示更多的2条评论
