跳转到主内容
机器可读指令,可以指导计算机处理器从互联网上下载和渲染“猫”的图像。
210 个问题 查看全部
Microsoft applications started to fail as well as some others.
Most Microsoft applications wont function on my computer please help.
Today I got on my computer it was fine, I played a couple games on it and saw that my nvidia driver needed an update, so I let that update. It then told me to restart I hit that I would do so later. Then I thought I might as well scan my computer for viruses as well with Webroot, so I started that. It found maybe 4 viruses. I told it to delete them. It also tells me that I have unnecessary files in my temp (temporary) folder, so I went to the folder to delete them. Then after doing all of this my computer began to run slow on certain applications. Microsoft Edge, my windows key was no longer functioning (this has happened before but a simple shutdown fixed it). Many others, so I thought maybe I should just restart my computer and it'll be fine. This is how it normally works. So my computer reboots. I log onto it and I get 3 pop ups from my applications. Discord, Skype, and Microsoft OneDrive. It tells me that it can't find any directories. Along with this I get maybe 10 notifcations saying that my default (pictures, browser, media player, etc.) has been reset to default. Along with this when I log back into google chrome (because ms edge wasn't working) I no longer have any saved passwords, themes, extensions. I go back into my recycling bin to retrieve my temp files in hopes that it can fix it. Nothing changes. I go and revert back to my nvidia driver before. Still doesn't work. Microsoft edge and windows key still not functioning. I revert some of the 'infected' files back onto my computer, yet still nothing changes. Along with that with software for my razer products (razer synapse) is no longer functioning. When I also open Nvidia Experience it gives me a login screen which I used to be logged into. Then upon signing in, it tells me that it crashes. When looking at the stats on my computer, my CPU, GPU, memory, etc. everything is running perfect. Even my games run at the same frames as before. Please send some solutions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
TaP Gaming sounds like some of your installed software files got deleted. This may have happened during the virus removal since those files may have been infected. Try to reinstall those programs that do not work
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TaP Gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 35
