跳转到主内容
加入维修社区 - 创建账户
2011 年发布的 ThinkPad。此版本的 T420 比 T420s 更厚,且没有集成 USB 3.0。T420i 使用相同的底盘,因此大多数 T420 维修指南可以通用。
Sim card slot problem
My lenovo thinkpad t420 has a sim card slot under the battery but it does work
is it whether the slot is fake or there is other problems with it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
You do not need lenovo access communications software to run the modem card. Simply use the internet settings in windows, and double check the sim card is activated and inserted the correct way.
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Hi!
Many business class laptops have SIM slots under the battery, but they only work if there's a special PCIe WWAN to connect to the carrier installed. You can check if yours has that component if you follow thisvideo and open your laptop up.
Thisis how the part looks like, if you'd like to get yourself one.
这个答案有帮助吗?
得分 3
3条评论:
The SIM card slot on the T420 is in the battery bay, but the WWAN card is located by the bottom RAM module. That's the WiFi card.
T420 RAM
由完成的 分享
I have a t480 and i inserted a active simcard from my tablet but still no mobile internet access. Is there an extra step or software i need to download to read the simcard?
由完成的 分享
@Raj Garcha Is it have a WWAN card? Most people pass on the option unless it's a major corporate purchase with a bulk data plan. I've never seen anyone take it personally.
It's usually on the spec sheet so if I'm not sure, then I can quickly see. They usually come with the systems when you buy them used, but some companies remove it.
由完成的 分享
添加一条评论
添加你的答案
pnshuti60 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 35
总计 11,384
