跳转到主内容
加入维修社区 - 创建账户
Mavic Pro是一款具有4K视频功能的可折叠,紧凑的无人机,于2016年11月首次发布。型号为M1P,其控制器型号为GL200A。
camera has water inside
hi there,
i was flying sideways and drowned my mavic pro in a tree which fall then in a river (sweet water). Found it again 24 hours later in about 4 meters under water -
everything works fine but it got water inside the camera which is now stuck on the glass in front of the lens and obviously can not disappear by itself. I opend the little screws but did not dare to go further as the parts did not want to get loose. I also see a golden ring near the lens cover which could hold it in place...?
any help?
Thanks anyway!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Do not charge it! Follow these guides to clean all the parts to help prevent water from corroding it. Do it ASAP!
Read this: Electronics Water Damage
Disassembly: DJI Mavic Pro 拆解
Proper cleaning demonstration: 修复iPhone 的进水故障
As for the camera, there is no hope. You'll need to replace it. Use the teardown to replace it and any other non-functioning part. I recommend taking it low and easy the first few flights to make sure everything's working.
Hope this helps!
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
DJI Mavic Pro图片
指南
DJI Mavic Pro 拆解
难度:
中等
这个答案有帮助吗?
得分 3
3条评论:
In that case that the camera can not be opened I try to remove the glass and find something to replace it (because the camera is working fine, it is only a waterdrop behind the glass which is in the view,..), if i kill it i have to excange it anyway...
Thank you!
由完成的 分享
actually maybe just exchange open the glas, release the moisture and put on a ND filterlens would solve the problem :)
由完成的 分享
Jeronimo I do not recommend that. You should replace it. 24Hr underwater also penetrated the sensor, which you can not fix. Have you cleaned the drone using the instructions above? This is something you should have done days ago. If you haven't done it yet, then the corrosion has probably already caused irreversible damage.
由完成的 分享
添加一条评论
添加你的答案
jeronimo 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 24
总计 2,173
