跳转到主内容
加入维修社区 - 创建账户
Vostro 是戴尔于 2008 年底推出的一款面向普通用户的商务笔记本电脑。它定价合理,型号为 A860。
Not seeing the home screen
After switching it, it starts loading then it goes back to the first step of the switching .it goes back before I see the home screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@yvette7 I am a bit confused by your question. You need to let us know exactly what your computer is doing and what your operating system is. If it cannot start the OS then it is most likely an issue with the file structure on that and it may need a repair or new install. If it is on the splash screen as your computer loads you do want to try to get into the BIOS and check the settings on that. Consider changing the boot order and use a bootable disk or USB drive to see if that will load on your computer. If so you know that you are having a problem loading your OS. So let us know what you mean by "starts loading" and what "the fist step" is that you see. To access your BIOS try these
Turn on or reboot your computer.
Press "F2" continuously during the reboot process until you see the message "Entering Setup." On some older systems, you may need to press "Delete," "Ctrl + Alt + Enter," "Fn + F1" or "Fn + Esc."
Navigate through BIOS using your arrow keys. Your mouse will not work in BIOS.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yvette kagoyire 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 280
