跳转到主内容
加入维修社区 - 创建账户
2004-2008 款 F-150 皮卡于 2003 年 1 月推出,作为 2004 车型年产品,是第十一代重新设计的 F-150 系列。
emergency brake light switch
While emergency light on cruise control will not engage
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Enoch Vinnegar Jr not quite sure what you are asking. What emergency light on cruise control?
完成的
Was wondering where the switch that lights up the emergency brake light symbol on dash panel is located so I can change it. As long as this light is lite, my cruise control will not engage
完成的
添加一条评论
1个答案
已选择的解决方案
Enoch Vinnegar Jr there are a few possibilities. One being a bad parking brake switch or a bad switch in your brake fluid reservoir switch. This series has an issue with the wiring to the instrument cluster as well. Check on here for that. The image will show you where the parking brake switch is located
and this one
where the switch on your fluid reservoir is. You do want to check both of these switches for continuity.
这个答案有帮助吗?
得分 0
3条评论:
@oldturkey03 do you have a detailed document on how to remove the emergency brake assembly and driver's wiring harness under the dash? I may be missing information in my Ford tech service manual. I need to remove all this stuff to replace the floorpan. Same generation 2004-2008.
完成的
@Ben this is for the emergency brake 04 F 150 Parking Brake Still looking for the wiring harness.
完成的
@Ben see if you can get the 2006 manual from here Let me know when you have it so I can remove the link
完成的
添加一条评论
添加你的答案
Enoch Vinnegar Jr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 69
总计 20,218
