跳转到主内容
加入维修社区 - 创建账户
2002 至 2007 年第一代 Nissan Murano 的维修指南与支持。
Grounding Points on 2005
I have a 2005 Nissan Murano and I am having a few issues with sensors and my engine running really rich. I was advised by a mechanic friend that the issue could be caused by a bad ground. I am trying to find all the grounding points on my SL Murano. I have only been able to find 2. 1 below the battery and 1 off the timing chain housing.
Any suggestions? or could i just run new grounds from the battery?
Thanks,
Jarrett
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Sande Jarrett it would probably be easier to run a new ground than trying to find a bad one. Make sure you remove all paint and primer before applying a new ground and use some self tapping screws to attach it.
Now if you really, really want to know where all the ground points are, here is the manual for that :-) Nissan-Murano-Ground-Distribution.pdf
这个答案有帮助吗?
得分 2
1条评论:
Thanks!!! this is really helpful.
由完成的
添加一条评论
添加你的答案
Sande Jarrett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 21
总计 5,870
